Categorizing Time
In this article: projects and clients, tasks, and tags.
Projects and Clients
Allocating your time entries to Projects allows you to generate useful reports more easily. You can create new Projects to assign your entries to from the Project page or on the Timer page while adding your time entries. Each Project can be tied with one Client.
When you assign your entries to Projects, you can group your data when running a Summary Report. When grouping your data by Project/Time Entry it will look like this.
You can also generate reports by choosing one (or more) Projects from the Filter option.
Tasks
Another way to categorize your time would be using Tasks (Starter feature):
Tasks allow an extra level of hierarchy within projects.
Organizing your time by Tasks is also possible from Reports the same way as it works for Projects.
Tags
There’s one more way to categorize your time. It’s especially recommended if you would like to mark your Time Entries “billed” or “invoiced” and generate your Reports by that criteria. This feature is called Tags and that’s where you can add them to your Time Entries:
PS. You can create Tags from your Workspace Settings page as well.
If you didn't find what you were looking for, please write to support@toggl.com and we are happy to help!
Was this article helpful?
Yes
No
Thanks for giving us thumbs up! Any feedback is still welcome! Thanks for the feedback! Any ideas what we could do better?
* Please leave your e-mail if you'd like us to get back to you :)
Thanks for your feedback! We're always working to help you better!
Oops! Something broke. We're working on fixing it. Sorry
TOP
