Todoist Integration
In this article: what is Todoisthow does it workenabling the integration, starting the timer in Todoist.
What is Todoist?
Todoist is a to-do and task manager designed to keep you in full control of your projects everywhere: at home, work, school, online and even offline. The app works equally well for both freelancers and teams.
For more details about Todoist visit www.todoist.com
How Does it Work?
This integration is powered by the Toggl Button Chrome Extension. The extension is available for download inside the Chrome Webstore.
By enabling this integration you will be able to track time in Toggl while using Todoist. In other words, instead of visiting the Toggl website whenever you want to Start or Stop the timer you’ll be able to interact with the timer directly on the Todoist website. With the integration active you will see a “Start timer” button inside the Todoist interface.
Enabling the Toggl-Todoist Integration
  1. Download and install the Toggl Button Chrome Extension.
  2. Open the extension Settings and click on the “Permissions” tab.
  3. Enable the todoist.com integration.
Starting the Timer in Todoist
To start tracking time in Todoist simply click on the “Start timer” button located within each Todoist task. The name of the task you’re working on will be used as the description for your time entry.
When the timer is Off
When the timer is On
If you didn't find what you were looking for, please write to support@toggl.com and we are happy to help!
Was this article helpful?
Yes
No
Thanks for giving us thumbs up! Any feedback is still welcome! Thanks for the feedback! Any ideas what we could do better?
* Please leave your e-mail if you'd like us to get back to you :)
Thanks for your feedback! We're always working to help you better!
Oops! Something broke. We're working on fixing it. Sorry
TOP
