Why upgrade?
In this table you’ll see tons of reasons to upgrade your workspace!
Free
pro
pro plus
Business
TIME TRACKING
Tracking reminders
Remind your team members to track time if they’ve tracked less than their target hours.
Close window
Tracking reminders
green check
optional
Tracking time
Track the time spent on various tasks and projects and later analyze your productivity. It is effortlessly simple and available on all platforms.
Close window
Tracking time
green check
green check
green check
green check
Deleting time entries
Delete unwanted time entries with a few simple clicks on the Timer page or in Detailed Report.
Close window
green check
green check
green check
green check
Bulk edit
Mass edit your data with a few simple clicks.
Close window
Bulk edit
green check
green check
green check
green check
Adding time manually
Not all time tracking needs to be done in real time. Add time later for activities that have already happened.
Close window
green check
green check
green check
green check
Timeline
Record every website and program that you view for longer than 10 seconds.
Close window
Timeline
green check
green check
green check
green check
Autotracker
Define applications or keywords that trigger the tracker and allocate the time to a previously determined project.
Close window
Autotracker
green check
green check
green check
green check
Tags
Add additional information to your time entries. Perfect way to mark what you’ve already billed.
Close window
Tags
green check
green check
green check
green check
Keyboard shortcuts
Save time by using keyboard shortcuts all across Toggl.
Close window
Keyboard shortcuts
green check
green check
green check
green check
Idle detection
Get notified of the time you’ve spent away from the keyboard and choose whether to keep the time, discard it or add it as a new entry.
Close window
Idle detection
green check
green check
green check
green check
Time formats
You can track time both in the 12-hour format and the 24-hour format.
Close window
Time formats
green check
green check
green check
green check
Offline mode
Track time even if you don’t have a network connection.
Close window
Offline mode
green check
green check
green check
green check
Pomodoro timer
Set up notifications that will let you know when it’s time to take a break.
Close window
Pomodoro timer
green check
green check
green check
green check
Reporting
Scheduled reports to email
You can save reporting filters, save the report and choose who you’d like it to be e-mailed to and when – daily, weekly or monthly.
Close window
green check
Optional
Time audits
Filter out all suspicious entries from your reports – either too short/long entries or the ones that are missing a project/task.
Close window
Time audits
green check
Optional
Locking time entries
You are able to prevent previous time entries from being edited by your team members by locking them.
Close window
green check
Optional
Billable rates
Insert hourly rates which are bound to time entry duration. Therefore you’ll see how much you earned with each particular job.
Close window
Billable rates
green check
green check
green check
Exporting (PDF, CSV XLS)
Export your data from Weekly, Detailed and Summary reports page to preferred format. Export to Excel is available for premium-plan users. CSV and PDF exports are available to free-plan users.
Close window
Exporting (PDF, CSV, XLS)
green check
green check
green check
Rounding
Round your time entries in your reports. Choose to round either up, down or to the nearest and choose preferred rounding range.
Close window
Rounding
green check
green check
green check
Saved Reports
Saved reports allow you to easily access your preferred report, with specified filters, date range etc. You can also share the saved report’s link with others.
Close window
Saved Reports
green check
green check
green check
Company logo
Uploaded logo will be displayed on your reports.
Close window
Company logo
green check
green check
green check
CSV import
Upload your data (clients, projects, users, time entries, tags) in bulk using the CSV import feature.
Close window
CSV import
green check
green check
green check
green check
Summary, Detailed, Weekly Reports
All of your data can be viewed in reports section. Pick the level of detail by choosing the report type; filter and sort your data, view it in pie charts and export your report.
Close window
green check
green check
green check
green check
Dashboard
Displays a detailed summary of your activities. Team tab allows you to check what your team is up to.
Close window
Dashboard
green check
green check
green check
green check
Project management
Project time estimates
You can estimate the time you think you’ll need for a Project, then you can see how your actually tracked time compares to that.
Close window
green check
green check
green check
Alerts for estimates
Admins, project managers or project members can get notified when a project has reached a certain percent of it’s estimated time.
Close window
green check
green check
green check
Tasks (sub-projects)
You can break down your Projects into more detailed lists. You can track time directly on these Tasks so you’ll know how much time each step took.
Close window
green check
green check
green check
Project Dashboard
Get a broad overview of how your Project is progressing. You can see which tasks took the most time and how much time your team already tracked compared to your Estimate.
Close window
Project Dashboard
green check
green check
green check
Project Template
Template allows you to create many similar projects quickly. All template project’s settings are applied to the new project.
Close window
Project Template
green check
green check
green check
Archiving projects
You can archive the projects you are done with to hide them while still keeping their data safe.
Close window
Archiving projects
green check
green check
green check
green check
Project colors
Mark your Projects with different colors to tell them apart at a glance.
Close window
Project colors
green check
green check
green check
green check
Unlimited Projects and Clients
Add as many Projects or Clients as you like and use them to organize the time you’re tracking.
Close window
green check
green check
green check
green check
team management
Editing team members profiles
Enables workspace administrators to edit team members’ names, access rights, billable rates etc
Close window
green check
optional
Adding time for team members
If a team member forgot to add time, then this feature enables administrators to do that for them
Close window
green check
optional
Required fields on a time entry
Define what your time entries must include: project, task, tag and/or description, and we won’t let them be saved or stopped until the format is correct.
Close window
green check
optional
Unlimited team size
Add as many users as you’d like to your workspace. Payments are automatic, monthly and per user.
Close window
Unlimited team size
green check
green check
green check
User groups
This feature is to make managing large workspaces a lot easier.
Close window
User groups
green check
green check
green check
green check
Deactivating users
You can temporarily deactivate a user without having to completely remove them from your workspace. Members listed in the Inactive tab are not billed for.
Close window
Deactivating users
green check
green check
green check
green check
Team’s access levels
Helps you to manage the access of different users in your workspace. There are three basic user access levels – workspace administrators, project managers and regular users.
Close window
green check
green check
green check
green check
Team Dashboard
Helps you to find out, who tracked the most time during last 9 days and most importantly – shows you what everybody is tracking in real time.
Close window
Team Dashboard
green check
green check
green check
green check
integrations
iCal feed
Integrate your Toggl time entries with Google Calendar
Close window
iCal feed
green check
green check
green check
Asana
Enables you to sync Asana users, projects and Tasks with Toggl.
Close window
Asana
green check
green check
green check
green check
Basecamp
You can import your users, projects, todo lists and todo items from Basecamp into Toggl so you never have to duplicate your work again.
Close window
Basecamp
green check
green check
green check
green check
Freshbooks
This integration helps you to sync Freshbooks Users, Projects and Tasks with Toggl.
Close window
Freshbooks
green check
green check
green check
green check
GitHub
Imports repositories from GitHub as Toggl projects.
Close window
GitHub
green check
green check
green check
green check
Teamweek
Integrates Toggl with a time-saving online project planner and team calendar.
Close window
Teamweek
green check
green check
green check
green check
apps & Support
Priority support
Your messages will always go to the front of the queue.
Close window
Priority support
green check
optional
Mobile (iOS, Android)
Track time from anywhere, even being offline. It’s fast, responsive and simple to use.
Close window
Mobile app (iOS, Android)
green check
green check
green check
green check
Desktop (Win, Mac, Linux)
Toggl Desktop is a small desktop application that will help you track time more conveniently. If you need track reminders, idle detection or Pomodoro, then that’s for you.
Close window
Desktop app (Win, Mac, Linux)
green check
green check
green check
green check
Toggl Button Chrome Extension
Chrome extension that lets you track time from your favourite online apps and in any other place, wherever you are on the web. Toggl Button is integrated with more than 50 tools.
Close window
green check
green check
green check
green check
You’ll find information about pricing from here
If you’re not sure which plan is the best for your needs, then please contact us to support@toggl.com and we’re happy to help!
If you didn't find what you were looking for, please write to support@toggl.com and we are happy to help!
Was this article helpful?
Yes
No
Thanks for giving us thumbs up! Any feedback is still welcome! Thanks for the feedback! Any ideas what we could do better?
* Please leave your e-mail if you'd like us to get back to you :)
Thanks for your feedback! We're always working to help you better!
Oops! Something broke. We're working on fixing it. Sorry
TOP
