Using Toggl Track with iOS Shortcuts
Get more done with Toggl Track's iOS Shortcuts
By using Shortcuts, you can get even more out of your day. Activate a Shortcut via a tap or Siri. Here's more on the Shortcuts Toggl Track offers for iOS users.
Setting up Shortcuts
To setup Shortcuts, open the Shortcuts App, click on the + button in the top-right corner, click Add Action and then search for Toggl Track to find our supported Shortcuts. Then you can add in the parameters (where needed), choose a name for your Shortcut and save it.
Available Shortcuts
The following Shortcuts are currently supported by Toggl Track and the parameters available.
Check Reports
Choose which period to report for, as well as the Workspace the report should be run for.
Continue Last Time Entry
Continues the last time entry in your time entry list
Start Time Entry
Start a time entry in the app with a specific Description and for a chosen Project. For the Description, you can Select a Magic Variable as well.
Stop Time Entry
Stops the currently running time entry.
While the sky is the limit for how you can use Shortcuts, here are some examples for how you can create Shortcuts using Track and other apps:
  • Start a timer based on your location to start a new timer whenever you enter work or make a site visit
  • View weekly time entry totals with a Check Reports shortcut
