Wunderlist Integration
In this article: what is Wunderlisthow does it workenabling the integration, starting the timer in Wunderlist.
What is Wunderlist?
Wunderlist is a to-do and reminder app that will make sure you get stuff done. It allows you to collaborate with anyone and stay on top of your list from anywhere. The service is available on desktop, mobile and even wearable devices.
For more details about Wunderlist visit www.wunderlist.com
How Does it Work?
This integration is powered by the Toggl Button Chrome Extension. The extension is available for download inside the Chrome Webstore.
By enabling this integration you will be able to track time in Toggl while using Wunderlist. In other words, instead of visiting the Toggl website whenever you want to Start or Stop the timer you’ll be able to interact with the timer directly on the Wunderlist website. With the integration active you will see a “Start timer” button inside the Wunderlist interface.
Enabling the Toggl-Wunderlist Integration
  1. Download and install the Toggl Button Chrome Extension.
  2. Open the extension Settings and click on the “Permissions” tab.
  3. Enable the wunderlist.com integration.
Starting the Timer in Wunderlist
To start tracking time in Wunderlist simply click on the Toggl icon located text to each Wunderlist task. The name of the task you click on will be used as the description for your time entry.
wunderlist
If you didn't find what you were looking for, please write to support@toggl.com and we are happy to help!
Was this article helpful?
Yes
No
Thanks for giving us thumbs up! Any feedback is still welcome! Thanks for the feedback! Any ideas what we could do better?
* Please leave your e-mail if you'd like us to get back to you :)
Thanks for your feedback! We're always working to help you better!
Oops! Something broke. We're working on fixing it. Sorry
TOP
