Toodledo Integration
In this article: what is Toodledohow does it workenabling the integration, starting the timer in Toodledo.
What is Toodledo?
Toodledo is a set of various tools aimed at increasing your productivity and overall organization. Think of it as a to-do list on steroids as it provides a place to write long notes, make custom lists, create structured outlines and track habits.
For more details about Toodledo visit www.toodledo.com
How Does it Work?
This integration is powered by the Toggl Button Chrome Extension. The extension is available for download inside the Chrome Webstore.
By enabling this integration you will be able to track time in Toggl while using Toodledo. In other words, instead of visiting the Toggl website whenever you want to Start or Stop the timer you’ll be able to interact with the timer directly on the Toodledo website. With the integration active you will see the familiar Toggl icon inside the Toodledo interface.
Enabling the Toggl-Toodledo Integration
  1. Download and install the Toggl Button Chrome Extension.
  2. Open the extension Settings and click on the “Permissions” tab.
  3. Enable the toodledo.com integration.
Starting the Timer in Toodledo
To start tracking time in Toodledo simply click on the Toggl icon located inside the tasks overview. The name of the task will be used as the description for your time entry.
Toggl timer turned off
Toggl timer turned on
If you didn't find what you were looking for, please write to support@toggl.com and we are happy to help!
Was this article helpful?
Yes
No
Thanks for giving us thumbs up! Any feedback is still welcome! Thanks for the feedback! Any ideas what we could do better?
* Please leave your e-mail if you'd like us to get back to you :)
Thanks for your feedback! We're always working to help you better!
Oops! Something broke. We're working on fixing it. Sorry
TOP
