Setting Up and Monitoring Projects
Projects in Toggl 2.0 are the central place to organize work, assign tasks, track time, and monitor progress — all from one view.
Creating a project
- Click the Add Project button.
- Enter the project name and any relevant details.
- You can also create a new client directly from this modal, without navigating away.
Duplicating a project
If you want to use an existing project as a starting point, you can duplicate it instead of building from scratch. To duplicate, open the project and click the three-dot menu on the right, then select Duplicate.
Duplication copies over all project setup data, including:
- Tasks and subtasks
- Estimates
- Priorities
- Billable flags
Note that time entries are not duplicated — only the project structure and settings are copied across. There is no selective duplication; everything listed above is always included.
Project estimates
Estimates can be set at the project level as a fixed total, or calculated automatically by rolling up individual task estimates. Both approaches feed into the progress tracking shown across the app.
Viewing project details
Once a project is created, open the Project Overview to see and manage everything in one place — project details, members, and links to project-specific views:
- Task list — all tasks for the project
- Timeline — tasks laid out across a calendar with dates and capacity
- Board — a kanban-style view for tracking task progress
Monitoring progress
There are two ways to keep an eye on how a project is going:
Project Overview page — the detailed view for a single project, where you can review status, make updates, and manage team members.
Project List — a high-level view of all projects at once. This is where the Time Status indicator gives you a quick read on each project:
- If a time estimate is set, Time Status shows your progress as a count and percentage toward that estimate.
- A green bar means the project is on track.
- A red bar means the project has gone over its estimate.
- If no estimate is set, Time Status simply shows total time tracked against the project.
Variance shows the difference between the project's time estimate and the total time tracked — useful for spotting scope creep or identifying where estimates need revisiting.
