Project Templates in Toggl 2.0
Project templates let you save an existing project’s structure and reuse it when starting new projects. This saves time on setup and ensures consistency across similar projects.
What is a Project Template?
A project template captures the key settings and structure of an existing project — including project members, billing, estimates, tags and tasks — so you can quickly replicate it without starting from scratch.
Project Templates are a paid plan feature
What’s Included in a Template?
When you create a template from an existing project, the following information is carried over:
| Included | Not Included |
| Project members | Start and end dates |
| Tags | Task due dates |
| Billing rates & estimates | Timeline structure |
| Fixed fee settings | Milestone dates |
| Task list with assignments & durations |
How to Create a Template
- Navigate to your Projects list
- Find the project you want to use as a template
- Click the three dots menu (⋯) next to the project
- Select “Save as template”
Your template is now saved and available for future use.
How to Create a Project from a Template
There are two ways to start a project from a template:
Option 1: From the new project flow
- Click “Templates” on the projects list header
- Choose a template
- Click “Create project from template”
Option 2: Direct template selection
- Click “New Project”
- Select “Start from a template” in the modal header
- Browse available templates and use the preview to review details
- Click “Use template”
The new project will open immediately in edit mode so you can customise the overview and tasks.
After Creating a Project from a Template
Once your project is created, you’ll likely need to:
- ✅ Update the project name
- ✅ Set the project start and end dates
- ✅ Rebuild your task timeline with the relevant dates
- ✅ Adjust any members, rates, or tasks as needed
Managing Your Templates
To view and manage all saved templates:
- Go to the Projects section
- Click the “Manage templates” button
From here you can review, edit, or delete existing templates.
Why aren’t dates included in templates? In the first version of templates, dates have been intentionally left out to avoid complexity around automatically calculating task start dates and maintaining timeline structure. This may be revisited in a future release based on user feedback.
Can I edit a template after creating it? Yes — you can manage and edit your templates via the template management view in the Projects section.
