Shortcuts in Toggl 2.0
Toggl 2.0 has keyboard shortcuts for every core action. This guide lists every available shortcut, grouped by what you are doing in the app.
You can do almost everything in Toggl 2.0 without touching your mouse. Keyboard shortcuts let you create tasks, start and stop timers, jump between views, and enter Focus mode in a single keystroke. Once you learn the basics: A to add a task, S to start tracking, F to focus, you will move through the app significantly faster. Press ? at any time inside Toggl 2.0 to see the full shortcut list. This guide breaks them all down by context so you can find exactly what you need.
Task creation
- Type
Ain Inbox or Calendar view to start creating task inline- add a title to your task, then
+to add a project name, - set priority with
P1,P2andP3 type a dateto add a due date
- type
command + enterin MacOS/ctrl + enterin Windows to open the task modal - type
command + enterin MacOS/ctrl + enterin Windows again to save the task and close the modal
All shortcuts
Show keyboard shortcuts — ?
Dismiss/Cancel — Esc
Time tracking
Start time-tracking — S
Stop time-tracking — S
Enter Focus mode — F
While in Focus mode
Start counting up timer — U
Start counting down timer — D
Start Pomodoro — O
Open Pomodoro settings (when Pomodoro running) — OS
Tasks
Create a new task — N
Create a new task inline — A
Import tasks — I
Save and close task modal — ⌘↵
Delete task immediately — ⌥click 'delete task'
While editing task title in task modal
Pick a project — +
Set a priority — P1, P2, P3
Set a due date — enter date
While editing inline task
Save inline task — ↵
Open task modal — ⌘↵
Calendar
Jump to today — T
Duplicate time block — ⌥ drag time block
