Rounding
Find out how you can turn on rounding of your time entries to the nearest chosen time increment
Vedran avatar
Written by Vedran
Updated over a week ago
Rounding time entries in Reports and Insights is a paid feature. It's not available with the Free plan.
You can choose between:
  • Round up to
  • Round to nearest
  • Round down to
The available intervals are: 1 minute, 5 minutes, 6 minutes, 10 minutes, 12 minutes, 15 minutes, 30 minutes, 1 hour and 4 hours.
Enabling Rounding in Reports and Insights
By default, Reports and Insights will use the Rounding settings you chose.
Click on the "Rounding button" on the screen you're looking at to change this.
Enable Rounding
You can click on the Settings cog to adjust the Rounding. When the toggle switch is pink, you've managed to turn rounding on. When it is grey, rounding is off.
Set Rounding
  • Time entries can be rounded up, down or to the nearest value.
  • You will have a variety of rounding ranges to choose from.
  • When adding up the duration of several Time Entries, the duration of each entry will be rounded separately in Reports.
  • Reports and Insights share the Rounding control. Settings applied in one will be applicable in the other as well.
If you still have questions about Rounding, please contact our Support team by clicking on the purple chat icon in the bottom right corner of this page to start a chat.
